Do you want to learn how to convert HEIC photos on DropBox to JPG? Refer to this guide as here is a complete guide to how to convert HEIC images on DropBox to JPG.
After updating an iOS device to the iOS 11 version, users find that images in iDevice are saved as HEIC format instead of JPG format. HEIC is a new image format introduced in iOS 11, Known as High-Efficiency Image Format. This new image format lets you keep an image at half the size of the file without quality loss, which can save your iDevice storage to a great extent. However, the main problem for users is that this new image type does not work on Windows PC, Android devices, and Mac system running below macOS High Sierra.
So, if you have HEIC images on your DropBox and want to share with others, then it is better to convert them into the most compatible format i.e. JPG. Here, in this guide, we have a complete guide on how to convert HEIC photos on DropBox to JPG.
DropBox offers a reliable platform for users to organize HEIC image files in a much better way. In fact, it let you easily view the HEIC files. So, if you want to learn how to upload HEIC photos to DropBox, then follow the below steps:
Step 1. Generate to DropBox online and then sign in.
Step 2. Next, click on “Upload” and then, based on your case, select the HEIC files or the Folder contains the HEIC images you want to upload to your DropBox account.
How to Upload HEIC Photos to DropBox – Step 2
Step 3. After that, select the files or the folder. And finally, click on the “Open” button.
How to Upload HEIC Photos to DropBox – Step 3
The HEIC photos will be auto uploaded to your Dropbox account within several minutes. Also, if you have installed the Dropbox app on your computer, you can launch it to upload HEIC photos to your account.
Just like uploading HEIC photos to DropBox, you can download HEIC photos from DropBox with ease. All you have to do is to select and then, download the photos you want. Below are the simple steps on how to download HEIC photos from DropBox to the computer:
Step 1. Sign-in your DropBox account and then, find and select the HEIC images you want to download.
Step 2. Next, tap on “…” icon and you will see options, such as “Invite to Folder”, “Share Link”, “Download”, and many more. Finally, tap on the “Download” button to download selected HEIC images to a computer.
Once you downloaded HEIC photos to the computer from DropBox, the next step in to convert them into the most compatible format. Luckily, iMobie HEIC Converter can help you with this. It is a free online HEIC converter that will let you bulk convert HEIC files or folders to JPG without any loss in the image quality. This online HEIC converter tool has really made easier for users to open and view HEIC files on every platform. Amazingly, this online tool perfectly works on both Windows and Mac systems.
Here is a simple guide on how to use iMobie HEIC Converter to convert downloaded DropBox HEIC images to JPG format:
Step 1. To begin the process, go to the iMobie HEIC Converter site and then, tap on the “Click to Start” button to add downloaded HEIC images you want to convert.
How to Convert DropBox HEIC Photos to JPG – Step 1
Step 2. Next, the tool will convert selected HEIC images to JPG format and you can also choose the image quality i.e. Standard, Medium, and High as you want.
Step 3. Finally, click on “Download All JPGs” to save JPG images to your computer.
How to Convert DropBox HEIC Photos to JPG – Step 3
That’s all on DropBox convert HEIC to JPG. With iMobie HEIC Converter, you can convert either single or multiple HEIC images in an easy and fast way. This virus-free tool is completely free to use that will also let you preserve EXIF metadata of HEIC images.
FREE & Simple Tool to Convert Any HEIC File to JPG in 3-Step:
How to Convert HEIC to JPG on Google Drive Easily
How to Download HEIC Photos as JPG in Google Photos
How to Convert HEIC to PDF for Free
How to Open and View HEIC File on Android
What is HEIC File and How to Open It
How to Change a HEIC File to JPEG on Mac/PC
How to Convert HEIC to JPG Online
How to Change a HEIC File to JPG on iPhone
The Best 5 Free HEIC Viewer for Windows and Mac
Top & Free HEIC File Converter for Windows/Mac
How to Open a HEIC File on Windows and Mac
How to Convert HEIC to JPG for Free on Mac/Windows
